Parallel Plate Capacitor
This is my first time using Comsol. My project is to model the capacitance of a system with the dimensions as follows:
Top Electrode: 2e-3m x 2e-3m x 100e-9m
Silicon Substrate: 2e-3m x 2e-3m x 2e-6m
Gap: 1e-6m
Bottom plate: 3.5e-3m x 3.5e-3m x 2e-6m
Bottom Electrode: 3.5e-3m x 3.5e-3m x 100e-9m.
Because Comsol cannot automatically mesh over these dimensions, I decided to reduce the system down into something Comsol could mesh first. Then I would build the 2e-3 and 3.5e-3m dimensions from this smaller one.
These dimensions are:
Top/Bottom Electrodes: 1e-4m x 1e-4m x 100e-9m
Top/Bottom Substrates: 1e-4m x 1e-4m x 2e-6m
Gap: 1e-6m
I managed to get Comsol to solve this system by following the documentation for the Capacitive 3D Comb Drive:
file:///C:/COMSOL35/doc/mems/wwhelp/wwhimpl/common/html/wwhelp.htm#href=memsactuatormodels.18.4.html&single=true
When I try to add another version of the above system by using Copy+Paste, the array tool, or the mirror tool, Comsol will not mesh this structure either (Error 4100). I tried using the "Interactive Meshing" feature and meshed each boundary, but then I get Error 7067: System Matrix is 0.
I would appreciate any help and suggestions anyone has... I've been stuck on this problem a while.
4 Replies Last Post 2012年6月18日 GMT-4 13:53
Posted: 1 decade ago 2012年6月14日 GMT-4 01:01
when you have such thin layers, the best is to use "surface thin" boundaries, as if you want to know something about what happens inside the 3D thin layers you must mesh them with 3 or more elements in the thickness, and your RAm and solving time explodes
check the doc
Hi when you have such thin layers, the best is to use "surface thin" boundaries, as if you want to know something about what happens inside the 3D thin layers you must mesh them with 3 or more elements in the thickness, and your RAm and solving time explodes check the doc -- Good luck Ivar
Posted: 1 decade ago 2012年6月14日 GMT-4 20:21
Are the "surface thin" boundaries part of a specific module, if so which one?
The problem with designating the mesh with 3 or more elements is that I made a composite object with the surrounding air and the two electrodes (as in the Capacitive Comb model documentation). Can I still manually mesh this object?
Also, which "doc" are you talking about?
Thanks for the quick response.
Are the "surface thin" boundaries part of a specific module, if so which one? The problem with designating the mesh with 3 or more elements is that I made a composite object with the surrounding air and the two electrodes (as in the Capacitive Comb model documentation). Can I still manually mesh this object? Also, which "doc" are you talking about? Thanks for the quick response.
Posted: 1 decade ago 2012年6月15日 GMT-4 00:55
you should always be capable of meshing a model, and it should solve with only 1 element in the thickness, the thing is how representative is it ?, are variations of your dependent variables, in the thickness of the part, important at all ?
Sometimes, to make the messhing easier it is worth subdividing the geometry into several domains with "internal" boundaries, that are there "just to help" the mesher. If your model can be made from only recangles or blocks, its often worth to make many of them and its not always worth to make unions and differences, just leave the last "geometry - Union" mode athe the Finish line (geomanalyze in 3.5) do the domain sorting
Hi you should always be capable of meshing a model, and it should solve with only 1 element in the thickness, the thing is how representative is it ?, are variations of your dependent variables, in the thickness of the part, important at all ? Sometimes, to make the messhing easier it is worth subdividing the geometry into several domains with "internal" boundaries, that are there "just to help" the mesher. If your model can be made from only recangles or blocks, its often worth to make many of them and its not always worth to make unions and differences, just leave the last "geometry - Union" mode athe the Finish line (geomanalyze in 3.5) do the domain sorting -- Good luck Ivar
Posted: 1 decade ago 2012年6月18日 GMT-4 13:53
I believe any variation in the thickness are important. I have tried subdividing the geometry up, but I did not use the Union at all. Should I use this after I define all boundary conditions?
When defining boundary conditions I was wondering if you could tell me the difference between using Distributed Capacitance vs Zero Charge/Symmetry? I am currently defining the Silicon substrates in between the two gold electrodes (the dielectric) with the Zero Charge.
--Jordan
I believe any variation in the thickness are important. I have tried subdividing the geometry up, but I did not use the Union at all. Should I use this after I define all boundary conditions? When defining boundary conditions I was wondering if you could tell me the difference between using Distributed Capacitance vs Zero Charge/Symmetry? I am currently defining the Silicon substrates in between the two gold electrodes (the dielectric) with the Zero Charge. Thanks, --Jordan
