Error while Running Simulation
I started getting this error all of a sudden and it says not enough disk space. I have 128GB of free space and still I am getting this error.
Does anyone have anyidea about how to resolve it?
Kind Regards,
MKSharma
3 Replies Last Post 2012年8月21日 GMT+8 21:23
Posted: 1 decade ago 2012年8月21日 GMT+8 02:17
Hi there!
I experienced similar troubles, though my simulation just chrashed. You are probably simulating a 'transient study' where Comsol acumulates the solutions to each time-step in the Temp directory of the system partition of the disk (c: in my case). I resolved it by reguraly deleting the Temp file and freeing enough memory space.
Another option is to change the Temp folder that Comsol uses to a disk with a lot of space. There are some threads how to do this on this forum.
I don't know if your problem is the same as I had, nevertheless maybe this answer will help you in some way...
Best of luck!
Hi there! I experienced similar troubles, though my simulation just chrashed. You are probably simulating a 'transient study' where Comsol acumulates the solutions to each time-step in the Temp directory of the system partition of the disk (c: in my case). I resolved it by reguraly deleting the Temp file and freeing enough memory space. Another option is to change the Temp folder that Comsol uses to a disk with a lot of space. There are some threads how to do this on this forum. I don't know if your problem is the same as I had, nevertheless maybe this answer will help you in some way... Best of luck!
Posted: 1 decade ago 2012年8月21日 GMT+8 16:19
You should try to adjust Study Times (Time Dependent), like this:
Times: range(0,0.01,100) ---> change to range(0,2,100)
Because you reduce the numbers of calculate time, you will get smaller file.
Hi, You should try to adjust Study Times (Time Dependent), like this: Times: range(0,0.01,100) ---> change to range(0,2,100) Because you reduce the numbers of calculate time, you will get smaller file.
Posted: 1 decade ago 2012年8月21日 GMT+8 21:23
thank you guys..my problem is solved
MKSharma
thank you guys..my problem is solved -- MKSharma
