error message!!!!
Hello
I am getting the following error message
"Out of memory during assembly".
How to overcome that?
rgds
Anup
2 Replies Last Post 2013年11月17日 GMT-5 03:39
Alberto Garcia-Cristobal
Posted: 1 decade ago 2013年11月16日 GMT-5 07:17
You can try by changing the mesh type to normal..coarse ....If you dont see the error again that means the problem is on the memory of your computing machine.
Hi You can try by changing the mesh type to normal..coarse ....If you dont see the error again that means the problem is on the memory of your computing machine.
Posted: 1 decade ago 2013年11月17日 GMT-5 03:39
That's fine.
Now I got a new prob.
Actually I am using two different (coupled) physics in my model.
When I am running the Study-1(Physics 1) it's absolutely fine.
But, When I try to run Study-2 (Physics 2), "Out of memory in time-dependent solver" error appears and then terminate the program.
rgds
Anup
Hi That's fine. Now I got a new prob. Actually I am using two different (coupled) physics in my model. When I am running the Study-1(Physics 1) it's absolutely fine. But, When I try to run Study-2 (Physics 2), "Out of memory in time-dependent solver" error appears and then terminate the program. rgds Anup
