Clarification of expression : (acos(tpf.intnormr)) [Capillary filling]
Hey all,
i'm planning to model the capillary filling of different geometries. As introduction i've been studying the example from comsol : microfluidics module --> Two-Phase-Flow --> Capillary filling ls
under definitions/variables 1a there is the expression for theta : (acos(tpf.intnormr))[1/deg]
Can anyone explain to me how this expression is set up ?
cause 1 : i can't find the theta anywhere else in the model (the contact angle is later on defined as 3/8*pi rad)
and 2: if i try to use this expression in my own model it won't accept it.
hope you can help me out.
regards,
Remco
1 Reply Last Post 2014年9月17日 GMT-4 03:53
Hello Remco Vos
Posted: 1 decade ago 2014年9月17日 GMT-4 03:53
Hi.
'intnormr' is defined in 'Filling of a Capillary Channel—Phase Field' example. Look for it in documentation.
It looks like that:
Name Expression Unit Description
intnormr d(phipf,r)/sqrt(d(phipf,r)^2+d(phipf,z)^2+eps) Interface normal, r component
theta (acos(intnormr))[1/deg] rad Contact angle
Hi. 'intnormr' is defined in 'Filling of a Capillary Channel—Phase Field' example. Look for it in documentation. It looks like that: Name Expression Unit Description intnormr d(phipf,r)/sqrt(d(phipf,r)^2+d(phipf,z)^2+eps) Interface normal, r component theta (acos(intnormr))[1/deg] rad Contact angle
