                                2015年8月30日 GMT+8 23:23
I do not believe there one is better than the other, it all depends on what you are modelling.
COMSOL used discretization polynomials on-top of the standard elements, therefore tetrahedral elements work "better" here, than in older FEM codes, with other underlying hypothesis. COMSOL has put meshing and the elements where they should be: a mathematical discretization of the geometrical space, such to resolve correctly the dependent variables and their variations of the differential equations you want to solve.
If you are a beginner (with COSMOL) use the default mesh settings, once you master them, play with the density: normal, fine, finer ... and check what is going on: are your results "better" ( 1) be sure you know what is "better" and 2) these effects will be different for each of your models), you need to learn why, be curious, try out "toy-models" to understand the relation to mesh density, discretization order and coherence of the results, all depending on the type of equations you solve: Poisson, diffusion, wave, NS ...
I use generally structured meshes for very anisotropic shaped geometries, and when the dependent variables do not change much (small gradients) with respect to the "thin" thickness dimension, and also  often for 2-3D problems with 1-2D-Axi-symetric geometry and BC conditions, as here mostly the "phi" variation of your dependent variables are small and you are less disturbed by the radial dependence on the mesh size change, layer by layer, i.e. on axis lens and mirror opto-mechanics
