Optical active medium
Do anybody know how to define an active medium in comsol 4.0a? I thought if I set the Relative permittivity to be complex and set the imaginary part to be negative, my medium will work like a active medium. But it seems that it is not that easy.
Best
9 Replies Last Post 2010年12月16日 GMT+8 17:36
Posted: 2 decades ago 2010年10月22日 GMT+8 14:34
I think it is that easy - just remember that comsol uses negative sign of imaginary part for absorption and positive for gain :) This is because in Comsol exp(i*w*t) is used as the time harmonic factor.
Posted: 2 decades ago 2010年10月23日 GMT+8 02:15
Shakeeb
Thank you for your reply. My results say something else. I want to calculate the quality factor of a ring resonator. When my refractive index is real I get a number and I make my medium active, I expect to get higher Q-factor (The gain compensate the losses ) . When I make my refractive index complex, with either negative or positive imaginary part, I get a very low quality factor. That seems to me comsol get the imaginary part as loss in any case. Do you have any idea?
Best
Faraz
Shakeeb Thank you for your reply. My results say something else. I want to calculate the quality factor of a ring resonator. When my refractive index is real I get a number and I make my medium active, I expect to get higher Q-factor (The gain compensate the losses ) . When I make my refractive index complex, with either negative or positive imaginary part, I get a very low quality factor. That seems to me comsol get the imaginary part as loss in any case. Do you have any idea? Best Faraz
Posted: 2 decades ago 2010年10月24日 GMT+8 22:56
Well, I am sorry I cannot comment on the peculiarities in your result but I know for sure that in Comsol positive imaginary part means gain and negative loss. This much is settled.
All the best :)
Well, I am sorry I cannot comment on the peculiarities in your result but I know for sure that in Comsol positive imaginary part means gain and negative loss. This much is settled. All the best :)
Posted: 1 decade ago 2010年12月10日 GMT+8 11:59
how abt gain saturation?
Posted: 1 decade ago 2010年12月10日 GMT+8 14:41
have you tried to write the imaginary part as a function of the total E intensity ?
Hi have you tried to write the imaginary part as a function of the total E intensity ? -- Good luck Ivar
Posted: 1 decade ago 2010年12月10日 GMT+8 23:44
I doubt if it is possible. Harmonic propagation is strictly for linear effects. For nonlinear stuff you have to use transient analysis. But be sure to check if it is fully equipped to handle all requirements of your simulation.
Hi, I doubt if it is possible. Harmonic propagation is strictly for linear effects. For nonlinear stuff you have to use transient analysis. But be sure to check if it is fully equipped to handle all requirements of your simulation.
Posted: 1 decade ago 2010年12月11日 GMT+8 00:31
indeed that is a good remark, time transint takes time though
Hi indeed that is a good remark, time transint takes time though -- Good luck Ivar
Posted: 1 decade ago 2010年12月16日 GMT+8 03:21
hi to all
i want to know, do comsol FDTD method for simulation of laser?
hi to all i want to know, do comsol FDTD method for simulation of laser?
Posted: 1 decade ago 2010年12月16日 GMT+8 17:36
Comsol has a transient solver which can basically do the things any FDTD program would.
However, beware that the transient solver until 3.5a is not in the best equipped form. Lack of PMLs and any built-in support for metals make it practically useless for a lot of realistic scenarios. Don't know if in 4.x series this has been upgraded.
Comsol has a transient solver which can basically do the things any FDTD program would. However, beware that the transient solver until 3.5a is not in the best equipped form. Lack of PMLs and any built-in support for metals make it practically useless for a lot of realistic scenarios. Don't know if in 4.x series this has been upgraded.
