Jeff Hiller
COMSOL Employee
8 years ago
2016年3月17日 GMT-4 14:22
Hello Nhan,
I suspect you misunderstand what a time-dependent solver does, or that you are trying to abuse time-dependent solvers to accomplish something that they are not intended for (and can likely be done better some other way). Time-dependent solvers are used to solve problems that evolve continuously over a time range; they are not intended to be used to solve sequences of discrete solution steps. The latter can be accomplished in other ways, including some that other Forum users have pointed out in response to your previous postings on this topic (i.e. programming through MATLAB or the App Builder).
Should you need further assistance, we invite you to please contact COMSOL's support team to discuss the best approach to follow.
Hello Nhan,
8 years ago
2016年3月17日 GMT-4 22:57
Hi Jeff,
First, thanks a lot for your help !
I may misunderstand the functionality of Time-Dependent Solver.
All I want to know is how to solve sequences of solution steps related with time.
At t=0, A is solved and then B,C,D,..... (B,C,D,... use solution from A)
At t=0+delta(t), A (use solution from B,C,D,..) is solved again and then B,C,D,...(B,C,D,... use solution from A).
Can you give me a hint to implement that ?
It'll be great if you help me.
N.N
Hi Jeff,
N.N
