Lars Gregersen
COMSOL Employee
9 years ago
2016年6月23日 GMT-4 05:25
Hi John
Please send your model to support where someone will have a look.
I received an error when I tried to compact my Comsol file
Syntax error in expression
- Expression: SpaceCharge(root.x[[um]],root.y[[um]])
- Subexpression: [[um]],root
- Position: 19
I cannot understand where the error is coming from. SpaceCharge is an interpolation function.
Lars Gregersen
Comsol Denmark
Hi John
[QUOTE]
- Position: 19
[/QUOTE]
Lars Gregersen
Comsol Denmark
9 years ago
2016年6月23日 GMT-4 09:54
I have attached the model.
Daniel Smith
COMSOL Employee
9 years ago
2016年6月23日 GMT-4 10:45
Hi John, the problem seems to be with the disabled "2DPlot Group 1" feature under Results. In the "Surface 1" plot, the expression is set to SpaceCharge(root.x[[um]],root.y[[um]]). COMSOL can't interpret the double square brackets when compacting history. To fix the problem, simply replace the expression with SpaceCharge(root.x[um],root.y[um]). You should be able to compact history after making this change.
Dan
Dan
