Save results from non converged analysis in master file when using batch sweep
Posted 2016年10月14日 GMT+8 21:53 Results & Visualization, Studies & Solvers, Structural Mechanics Version 5.2a 0 Replies
I'm using a batch sweep for one parameter "R" to analys how an irregular geometry will influence the load carrying capacity of a concrete slab. For each anlysis a random geometry is generated (by the parameter R) and a precrisbed displacement is then applied. The displacement is applied as a function of time, i.e. a time-dependent analysis is used. The concrete is unreinforced and each failure will therefore in this case be initiated by a drop in the reaction forces in the model. I would like to extract the maximum reaction force from each analysis but encounter some problems when convergence is not reached. I choosed the option to store all solutions in one file.
I found the option so that the program continue the sweep with the next value of "R" when convergence is not reached for a value of "R".
However the solution from this non-converged parameter is not stored in the "master-file" where all converged solutions is stored. To acces the results from the non-converged analysis i have to manually open the stored solution. This will be very time consuming when doing a large number of analyses.
Is there a way of doing this automatically in Comsol? That is, to store the solution from the last converged step from the non-converged solution into the "master-file"? In my case i would just like to save the maximum reaction force from the last converged step in the failed analyses.
// Andreas
Hello Andreas Sjölander
