heat pipe and porous material
Posted 2017年6月27日 GMT+8 01:55 0 Replies
Im doing a simulation of heat pipe porous, this is the 2D model of the 2 blocks (vapor chambor and porous material), when i add a laminar flow respectively to the vapor core and the wick in order to add a mass flow in the interface, it can not find a result for my case, when i use the same setting with only the wick, it can work, and have the correct result. The mph file i also add it in the attach file, it has confused me for a long time, i completely dont know where is the problem, is there some people can help me? Thank you in advance
Regards
Ma Yue
Hello Yue Ma
