How can i embed a 2D object into 3D
I have a cylindrical block and wanrt to insert a flat contact on top.
so i created the flat contact in workplanes, but i cant find the way to embed it into the 3D feature.
Any help.
Regards-LINDA!
3 Replies Last Post 2011年6月20日 GMT+8 23:41
Posted: 1 decade ago 2011年4月1日 GMT+8 15:27
What do you mean by '3D feature'?
If done correctly you can just add boundary or edge conditions to the 2D workplane created in a 3D model.
What do you mean by '3D feature'? If done correctly you can just add boundary or edge conditions to the 2D workplane created in a 3D model.
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 2011年4月1日 GMT+8 15:53
A 2D geometry object in a work plane is automatically inserted (embedded) as a 2D object in the 3D geometry when you build the final geometry (unless you first extrude or revolve it into a 3D object).
Magnus Ringh, COMSOL
Hi, A 2D geometry object in a work plane is automatically inserted (embedded) as a 2D object in the 3D geometry when you build the final geometry (unless you first extrude or revolve it into a 3D object). Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 2011年6月20日 GMT+8 23:41
Hi there
I understand that the 2D object is automatically embedded into a 3D geometry, but how can I assign a physics to this embedded 2D object? In my case, I am using 4.0, and I could not see the 2D object i.e. circle, therein I could not assign any physics to it. Kindly advise. Many thanks!
liwah
Hi there I understand that the 2D object is automatically embedded into a 3D geometry, but how can I assign a physics to this embedded 2D object? In my case, I am using 4.0, and I could not see the 2D object i.e. circle, therein I could not assign any physics to it. Kindly advise. Many thanks! liwah
