Apply a load for Midlin plate
I am new in Comsol. I have some problems with applying load (it has sinusoidal form). I compared the results with solution received by clasical theory and by improved theory. Can You help me find solution by Comsol too. I could not find , how I can give the load by function.
Thank You beforehand.
1 Reply Last Post 2011年5月4日 GMT+8 04:32
Posted: 1 decade ago 2011年5月4日 GMT+8 04:32
If you have a harmonic (load sinus type) then you should consider harmonic solver or frequency domain solver, these are based on a harmonic signal development, you specify the amplitude , the frequency or frequency range ans sweep steps, possibly the phase, and you will get the rms values in response. Check the doc
Hi If you have a harmonic (load sinus type) then you should consider harmonic solver or frequency domain solver, these are based on a harmonic signal development, you specify the amplitude , the frequency or frequency range ans sweep steps, possibly the phase, and you will get the rms values in response. Check the doc -- Good luck Ivar
