Solver Problem
I could not find the reason of the error. Can anyone help me?
i tried all solvers none of them worked out.
2 Replies Last Post 2012年9月27日 GMT-4 09:16
Posted: 2 decades ago 2009年11月27日 GMT-5 15:28
I'm not sure its the solver that is doing something wrong, I have problems to understand your model.
First, when you select material from the library these are given mostly as function of T (and p for gases). But if you redefine T to T2 for some physics, the library material temperature variable is NOT renamed, you must check and correct it manually, if required.
I have also problems to understand your two chcc's, over the same volume ?
But it's Friday night and I'm rather tired,
Hope it still can give you some clues
Hi I'm not sure its the solver that is doing something wrong, I have problems to understand your model. First, when you select material from the library these are given mostly as function of T (and p for gases). But if you redefine T to T2 for some physics, the library material temperature variable is NOT renamed, you must check and correct it manually, if required. I have also problems to understand your two chcc's, over the same volume ? But it's Friday night and I'm rather tired, Hope it still can give you some clues Good luck Ivar
Posted: 1 decade ago 2012年9月27日 GMT-4 09:16
This problem has been solved. It was a initialization problem. With default segregated solver, when opened in v4.3, there is no more this problem...
