Modelling Gaussian pulse in RF module
Posted 2011年6月3日 GMT+8 00:55 RF & Microwave Engineering Version 4.2 6 Replies
I am having a lot of trouble trying to create an electromagnetic source that follows a Gaussian pulse.
My first step after starting up the transient electromagnetic wave physics is to try to define a variable which holds the time description of the pulse:
v_pulse = v_0*exp(-(100-t[t])^2)
I think there is a problem with how I am using t. Any help is greatly appreciated.
Sincerely,
John
but you have already a predefine Gaussian "pulse funtion" in v4 (check under the Definitions node), the only thing to remember is that the input variable for functions must be made "dimensionless", hence use "t[1/s]", instead of just "t"
The setup with the built in function is a little different from what I want.
I am very new to the program and wondering, is it alright to model the pulse like this:
Under Variables:
expression: v_max*exp((-(100-t[1/s])^2)/100)
units: [V]
and then plug this into the electromagnetic wave; under Port 1
E_0 = gauss_pulse[1/m]
This is put into the y portion, and the x and z are left at 0.
Thanks for the help,
John
I am completely lost because whenever I try to do this in the transient electromagnetic module, the only option for port is LUMPED port. This is apparently only useful for metal interfaces. I also can't find the option for perfectly matched layers.
Online, all I can find are models and tutorials for constant sources in the steady state (such as joule heating through metal, etc). I am interested in the transient response to a short pulse, and am sure the solution is simple.
Any help is really, really appreciated.
-John
(I have attached my attempt in a module. I tried to label everything to make it as simple as possible).
The bad news for you is that Comsol does not have PMLs in transient simulations. The only source excitation and absorbing boundaries available are Scattering boundaries (that was until 3.5a). Now scattering boundaries, according to docs, are capable of absorbing plane wave reflections only. This really leaves the transient module extremely limited in application to realistic time domain simulations.
I will not worry about the PML for now.
All other things aside, I am just wondering how to create an electromagnetic wave with a gaussian profile and watch it propagate. Is this possible to do in COMSOL?
I am very lost but since this is the most basic part of my project I would really appreciate any help.
John
www.comsol.com/showroom/gallery/956/
