Can we impose a MINIMUM STEPSIZE AS A STOP CONDITION?
I loop thousands of transient simulations in matlab and I can't find a solver setting that will stop the solver when the step size becomes very small (history of the stepsize in log file) and the simulation becomes a terrible waste of time.
Is there a way to impose a low limit on the stepsize of the solver? I tried various Stop expressions with no success (ex. stepsize-1)...
Anyone knows how to do that?
Frank
4 Replies Last Post 2013年11月12日 GMT-5 23:41
Posted: 1 decade ago 2011年11月1日 GMT-4 08:07
Nobody uses such a stop condition?
I tried to play with the 'Limit on nonlinear convergence rate' under 'Damping and Termination' in 'Fully Coupled' under my Time-Dependent Solver. But in order to be able to adjust the Limit on nonlinear convergence rate, we have to choose a Constant Damping Method, and my solutions are much better when the Damping Method is set to Automatic (no oscillations, quicker, etc.). So I had to let go this possibility.
Anyone has an idea of a Termination technique when a Time-Dependent Solver progresses endlessly with very small stepsize?
Nobody uses such a stop condition? I tried to play with the 'Limit on nonlinear convergence rate' under 'Damping and Termination' in 'Fully Coupled' under my Time-Dependent Solver. But in order to be able to adjust the Limit on nonlinear convergence rate, we have to choose a Constant Damping Method, and my solutions are much better when the Damping Method is set to Automatic (no oscillations, quicker, etc.). So I had to let go this possibility. Anyone has an idea of a Termination technique when a Time-Dependent Solver progresses endlessly with very small stepsize?
Posted: 1 decade ago 2011年11月1日 GMT-4 08:21
If you want the solver to stop when the time step becomes smaller than a specific value X, add this expression as a Stop Condition “timestep-X”
Nagi Elabbasi
Veryst Engineering
If you want the solver to stop when the time step becomes smaller than a specific value X, add this expression as a Stop Condition “timestep-X” Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 2011年11月1日 GMT-4 16:02
It hurts...
Thank you very much, you made my day Mr Elabbasi.
It hurts... Thank you very much, you made my day Mr Elabbasi.
Posted: 1 decade ago 2013年11月12日 GMT-5 23:41
I have the same problem. Did you find any solution for that?
Thanks.
Marco
Hi, I have the same problem. Did you find any solution for that? Thanks. Marco
