2011年12月12日 GMT+8 14:48
have you tried the "waveform" functions in V4 ? these should do. They do also include a smoothing region to remain continuous, but they do not include any "offset", so you must combine them then with a other analytical function
2011年12月13日 GMT+8 04:46
Hi Ivar,
Thanks for your reply.
I tried using the waveform function. It appears to be what I am looking for.
But how do I apply such a waveform to the inlet as a periodic condition for concentration of species?
I also did not understand what you meant by combining the waveform with another analytic function
Hi Ivar,
2011年12月13日 GMT+8 14:23
the waveform is defined symmetric around "0" if you need to offset it, you might by calling it from another analytical function.
To use that in a BC definition you "simply" call the function depending on your time variable "t" i.e. wv1(t[1/s]) where the [1/s] is to make "t" without units and expressed in seconds (you might want to use "min" or "h" or "d" or "a" or "y" for minutes, hours, days or years/années instead of "s" for seconds"
This supposes that you use a time dependent solver.
Note: if for any reason you use a stationary solver to get the initial conditions, then the "t" will NOT be defined by default so your BC relying on "t" will be flagged ERROR. Try then to define a Parameter t = 0[s] this will solve the issue for the stationary solver, and the variable will be overwritten by the time dependent solver correctly
