problem with eigenfrequency
Hi all,
My project consists in calculating the eigenfrequency of a piezoelectric beam. For the experience, I apply 10V on the top, the ground is on the bottom. After, I mesh the beam, I solve and I obtain the eigenfrequency value.
But my problem is that when I change the mesh (I increase the number of elements), my eigenfrequency value change. And this until the solve stop because I'm out of computer memory. I think it isn't normal.
I can't obtain a correct eigenfrequency and I don't know why! If someone have a solution, please write me.
I work in 2D with MEMS module/Structural mechanics/Piezo plane stress
Thank you
3 Replies Last Post 2012年2月24日 GMT-5 08:51
Posted: 1 decade ago 2012年2月23日 GMT-5 15:13
I agree one should expect a saturation or stabilisation of the eigenfrequency values when the mesh becomes fine "enough". but this depends a little on the model and how it is set-up + the RAM size of your PC.
Perhaps, if your beam has a high aspect ratio and you are looking for high frequency modes that you really need a very high mesh density, or that a structured mesh would help.
Do not foget you solve for displacement, so your mesh must be denser (5-8 elements per mde wavelength in the material), if not you might have aliasing and your frequency will drift off with the mesh.
Have you estimated roughly by hand what you expect to find as frequency and spatial wavelength ??
Hi I agree one should expect a saturation or stabilisation of the eigenfrequency values when the mesh becomes fine "enough". but this depends a little on the model and how it is set-up + the RAM size of your PC. Perhaps, if your beam has a high aspect ratio and you are looking for high frequency modes that you really need a very high mesh density, or that a structured mesh would help. Do not foget you solve for displacement, so your mesh must be denser (5-8 elements per mde wavelength in the material), if not you might have aliasing and your frequency will drift off with the mesh. Have you estimated roughly by hand what you expect to find as frequency and spatial wavelength ?? -- Good luck Ivar
Posted: 1 decade ago 2012年2月24日 GMT-5 06:54
Hi Ivar,
Indeed the lenght is 260µm and the thickness is 180nm,so the ratio is important. In this case, what is the solution?
According to the datasheet, the eigenfrequency is in order of some 10kHz. The computer memory is 64Gbits, I this it is adequate. I give you in attachment my model (the PZT beam between the two electrods).
After, I would like to compare severals beam (lenght between 260 and 600µm), so the ratio increase? It is possible to realize this?
Hi Ivar, Indeed the lenght is 260µm and the thickness is 180nm,so the ratio is important. In this case, what is the solution? According to the datasheet, the eigenfrequency is in order of some 10kHz. The computer memory is 64Gbits, I this it is adequate. I give you in attachment my model (the PZT beam between the two electrods). After, I would like to compare severals beam (lenght between 260 and 600µm), so the ratio increase? It is possible to realize this? Thanks
Posted: 1 decade ago 2012年2月24日 GMT-5 08:51
one trick and comment. For such shapes, you should add a new Definition View node and unders Axis uncheck the "Preserve aspect ratio" andhit the geoemtry rescale ion to see the geoemtry better (but your dimension are now distorted, so when you mesh do not be scared it looks awful ;)
Sorry in 3.5 its elsewhere perhaps as a icone even but you have also the possibility to unlock axis scales
If you check your geoemtry, you have a few very small gaps, these might mess up your mesh. If these are relevant for your design (probably as they look more OK in the normal view), I would suggest, in case of meshing issues, that you cut up all your domains into rectangles (be "cubic" dfor such things) this adds a few internal boundaries but allows you to use easier structured and sweep mesh.
Another minor issue, you do not need to add two extra linear Elastic materials, if both are isotropic, you need only to add specific Linear material nodes when you mix isotropic and anisotropic materials. The material list tells COSMOL to refer to the correct material data so materials and linear elastic nodes might mix
But I get also strange shapes depending on the mesh, even if I remove the 4 pads, particularly with structured mesh, while I get a certain coherrnce with the results with thets. Your aspect ratio is really extreme. perhaps you should consider shell elements for the free memebrane but these are not that easy to knit in with strucutral
Hi one trick and comment. For such shapes, you should add a new Definition View node and unders Axis uncheck the "Preserve aspect ratio" andhit the geoemtry rescale ion to see the geoemtry better (but your dimension are now distorted, so when you mesh do not be scared it looks awful ;) Sorry in 3.5 its elsewhere perhaps as a icone even but you have also the possibility to unlock axis scales If you check your geoemtry, you have a few very small gaps, these might mess up your mesh. If these are relevant for your design (probably as they look more OK in the normal view), I would suggest, in case of meshing issues, that you cut up all your domains into rectangles (be "cubic" dfor such things) this adds a few internal boundaries but allows you to use easier structured and sweep mesh. Another minor issue, you do not need to add two extra linear Elastic materials, if both are isotropic, you need only to add specific Linear material nodes when you mix isotropic and anisotropic materials. The material list tells COSMOL to refer to the correct material data so materials and linear elastic nodes might mix But I get also strange shapes depending on the mesh, even if I remove the 4 pads, particularly with structured mesh, while I get a certain coherrnce with the results with thets. Your aspect ratio is really extreme. perhaps you should consider shell elements for the free memebrane but these are not that easy to knit in with strucutral -- Good luck Ivar
