specifying a global constraint on an internal variable
is there a way to specify a constraint that the average of a stress component must be zero?
2 Replies Last Post 2012年5月8日 GMT+8 14:32
Posted: 1 decade ago 2012年5月7日 GMT+8 16:59
i do not believe you have them "pre-cooked", but it should be possible via a weak equations or an external ODE
Hi i do not believe you have them "pre-cooked", but it should be possible via a weak equations or an external ODE -- Good luck Ivar
Posted: 1 decade ago 2012年5月8日 GMT+8 14:32
Hi Ivar,
Thanks for your reply. I tried to apply a global weak constraint on the model by assigning a average operator on the domain and then specifying the average of the stress component to be zero. But it does not work.
Hi Ivar, Thanks for your reply. I tried to apply a global weak constraint on the model by assigning a average operator on the domain and then specifying the average of the stress component to be zero. But it does not work.
