coupling operator from 2D to 3D
Posted 2012年6月12日 GMT-4 11:35 Parameters, Variables, & Functions Version 4.2a 2 Replies
Hi everybody,
I'm trying to map (with a coupling operator) a variable 'mod1.T', defined in a 2D domain (a square), to a 3D internal boundary (a vertical layer or a parametric surface inside a block, so a square in the first case, and a rectangle in the second one).
So I'm trying to do this by defining a LINEAR EXTRUSION, selecting the four vertexes of the source (square) and the four vertexes of the destination (layer/parametric surface). Then, in the Comsol node where I need to apply my new variable, I input the coupling operator name with 'mod1.T' as its argument.
But I obtain the message 'Error vertex selection, Error in multiphysics compilation'. I've tried to change the order of the vertex selection, I' ve created four points in the internal boundary to select them as 'vertex destination', and some weird ideas more... but nothing of I've done works.
Then I've changed the coupling operator, applying a GENERAL EXTRUSION, and the model runs without apparent errors, but the results are obsolet, by the way that my second study doesn't recognize the variable.
Why could it be produced? I've read the 'Coupling operators' chapter of the User's guide (only twice, maybe I need to read it again...) but I don't find the reason that this doesn't work...
Can you help me throwing some ideas or experiences? Thank you a lot.
Adriana
Adriana
2 Replies Last Post 2012年6月13日 GMT-4 12:48
