How to draw a half circle ??
Muthuraman Chinnadurai
Hi Friends,
can you help me to draw a half circle of radius 35mm.
Thanks in advance.
2 Replies Last Post 2012年9月21日 GMT-4 05:13
Posted: 1 decade ago 2012年9月21日 GMT-4 04:45
you have three ways:
1) draw the full circle, draw a box covering the half, subtract the box from the full circle.
2) insert the shape with the Bezier curves, you need to check the doc to get the correct sqrt(2) value in the right place
3) draw with freehand, via Bezier using the grid placed on the radius as help points
Hi you have three ways: 1) draw the full circle, draw a box covering the half, subtract the box from the full circle. 2) insert the shape with the Bezier curves, you need to check the doc to get the correct sqrt(2) value in the right place 3) draw with freehand, via Bezier using the grid placed on the radius as help points -- Good luck Ivar
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 2012年9月21日 GMT-4 05:13
Another option is to set the Section angle to 180 degrees in the settings window for the Circle geometry object.
Magnus Ringh, COMSOL
Hi, Another option is to set the Section angle to 180 degrees in the settings window for the Circle geometry object. Best regards, Magnus Ringh, COMSOL
