Body load in nonlinear mechanics
Hello, This is my first ever entry in the Discussion Forum, though I have been using the software since it was still Femlab 2.1 (circa 1998). I am trying to set up a nonlinear mechanic computation, where a body load at location (x,y,z) or material location (X,Y,Z), is defined as a function of the displacements (u,v,w) at that location (i.e. a function of u(X,Y,Z), v(X,Y,Z) and w(X,Y,Z)), and also (i.e. simultaneously) a function of the displacement at a different location (e.g. a function of u(X,Y,Z0), v(X,Y,Z0) and w(X,Y,Z0), where Z0 is a parameter). How do I go about this? Thank you, David
1 Reply Last Post 2024年1月9日 GMT+1 15:18
Posted: 3 years ago 2024年1月9日 GMT+1 15:18
Say that you wanted the load to be proportional to the difference in displacement. Then, you could for example write a function of u-at3(X,Y,Z0,u).
Note, however, that any function of the displacement that couples different locations in the structure will fill in the stiffness matrix significantly. This may cause a problematic increase in solution time if the model is large. It may then be beneficial to use the nojac() operator, as in nojac(u-at3(X,Y,Z0,u)). Then, you do not get the stiffness matrix contributions, but as a tradeoff there will be more iterations since the stiffness matrix is not optimal.
Henrik Sönnerlind
COMSOL
Say that you wanted the load to be proportional to the difference in displacement. Then, you could for example write a function of u-at3(X,Y,Z0,u). Note, however, that any function of the displacement that couples different locations in the structure will fill in the stiffness matrix significantly. This may cause a problematic increase in solution time if the model is large. It may then be beneficial to use the nojac() operator, as in nojac(u-at3(X,Y,Z0,u)). Then, you do not get the stiffness matrix contributions, but as a tradeoff there will be more iterations since the stiffness matrix is not optimal.
