Solving a 4th order PDE: how to specify boundary conditions
A fourth order PDE like the biharmonic equation: ∇^4 w = 0 can be placed in Comsol's standard forms by writing u = ∇^2 w, so that we have system of equations:
∇^2 v = w
∇^2 w = 0
where v = v(x,y) and w = w(x,y).
Suppose that in the original problem, I had the two boundary conditions:
w = 1 on D1
dw/dn = 0 on D1
w = unknown constant on D2
dw/dn = 1 on D2
I am not sure how I translate to the system now in (v, w). In particular, the value of w on the boundary D2 is unknown, but it is known that D2 is constant.
From my reading, it seems that I have to use the notion of Lagrange multipliers. But there is very little documentation on this in Comsol's manuals. I would appreciate if someone could help.
4 Replies Last Post 2012年12月24日 GMT+8 04:54
Posted: 1 decade ago 2012年12月21日 GMT+8 18:18
I also have a 4th-order PDE to solve, and it's more complex than the one in your question. I've been struggling with that for some time. Hope we both can solve our problems.
Here's a few thoughts about your question:
One thing to note is that the knowledge of Dirichlet boundary condition on a boundary enables you to calculate the tangential derivative of the dependent variable. So on boundary D1, dw/dt=0 (as your Dirichlet BC has a constant value) and dw/dn=0 means dw/dx=dw/dy=0, then everything about v on D1 is zero. For D2, dw/dt=0 and dw/dn=1. From these two conditions, I guess you can find the conditions for v on D2.
What I'm not sure about is which of these conditions one should impose explicitly as some of them are obviously redundant.
Best
Pu, ZHANG ??
Departamento de Física Teórica de la Materia Condensada,
Universidad Autónoma de Madrid,
Madrid, Spain.
Hi, I also have a 4th-order PDE to solve, and it's more complex than the one in your question. I've been struggling with that for some time. Hope we both can solve our problems. Here's a few thoughts about your question: One thing to note is that the knowledge of Dirichlet boundary condition on a boundary enables you to calculate the tangential derivative of the dependent variable. So on boundary D1, dw/dt=0 (as your Dirichlet BC has a constant value) and dw/dn=0 means dw/dx=dw/dy=0, then everything about v on D1 is zero. For D2, dw/dt=0 and dw/dn=1. From these two conditions, I guess you can find the conditions for v on D2. What I'm not sure about is which of these conditions one should impose explicitly as some of them are obviously redundant. Best -- Pu, ZHANG ?? Departamento de Física Teórica de la Materia Condensada, Universidad Autónoma de Madrid, Madrid, Spain.
Posted: 1 decade ago 2012年12月21日 GMT+8 22:23
Perhaps I'm being dense, but on D1, where w = 0 and dw/dn = 0 on the boundary, why does that necessarily imply that v = 0?
For example, take the function w(x,y) = x^3 y^2 along D1 defined by y = 0. Then both w = 0 and dw/dn = dw/dy = 0 on the boundary, but the laplacian of w (and thus v) is non-zero.
Do you know much about the Lagrangian multipliers option in Comsol? I see mu = [mu1, mu2] in the equation definition in the screenshot here: i.imgur.com/LCDpx.png, but where is this used and where is it defined? It does not appear in the Neumann/Flux condition.
[QUOTE] One thing to note is that the knowledge of Dirichlet boundary condition on a boundary enables you to calculate the tangential derivative of the dependent variable. So on boundary D1, dw/dt=0 (as your Dirichlet BC has a constant value) and dw/dn=0 means dw/dx=dw/dy=0, then everything about v on D1 is zero. For D2, dw/dt=0 and dw/dn=1. From these two conditions, I guess you can find the conditions for v on D2. [/QUOTE] Hi, Perhaps I'm being dense, but on D1, where w = 0 and dw/dn = 0 on the boundary, why does that necessarily imply that v = 0? For example, take the function w(x,y) = x^3 y^2 along D1 defined by y = 0. Then both w = 0 and dw/dn = dw/dy = 0 on the boundary, but the laplacian of w (and thus v) is non-zero. Do you know much about the Lagrangian multipliers option in Comsol? I see mu = [mu1, mu2] in the equation definition in the screenshot here: http://i.imgur.com/LCDpx.png, but where is this used and where is it defined? It does not appear in the Neumann/Flux condition.
Posted: 1 decade ago 2012年12月22日 GMT+8 21:11
Sorry, I made some mistake.
When w=const on D1, you have dw/dt=0. Together with dw/dn=0, you know dw/dx=dw/dy=0. But I think we can't get more.
Best
Pu, ZHANG ??
Madrid, Spain.
Sorry, I made some mistake. When w=const on D1, you have dw/dt=0. Together with dw/dn=0, you know dw/dx=dw/dy=0. But I think we can't get more. Best -- Pu, ZHANG ?? Departamento de Física Teórica de la Materia Condensada, Universidad Autónoma de Madrid, Madrid, Spain.
Posted: 1 decade ago 2012年12月24日 GMT+8 04:54
you don't need lagrange multipliers, just follow this example:
www.comsol.com/support/knowledgebase/816/
worked for me
you don't need lagrange multipliers, just follow this example: http://www.comsol.com/support/knowledgebase/816/ worked for me
