Stress simulation in electromagnets
Posted 2013年1月16日 GMT-5 07:55 1 Reply
Hi Comsol-Community,
since quite some time I am trying to simulate high field electromagnets with Comsol 4.3.
When it comes to simpe field calculations of (mostly) 2D-axisymm. coil magnets everything is fine.
Even the combination with the structural mech. module is working well in some simple cases.
Sadly, my newest simulation attempt gives me quite some headache:
I want to simulate the coil and lateron the stress generated by the lorentz force of the coils
own magnetic field. The coils should have a few layers of wire. Each layer is supposed to have a reinforcement in the radial direction. The magnetic pressure pushes the wires outwards. Since there is no fixed connection between the reinforcement of an inner coil layer and the following layer of wires, I tried to form an assembly instead of a union and this is where the problems start. Now neither the mf nor the solid simulations are working:
1. mf: When using assemblies, there's no error during the solving process, but the magnetic field is now confined to the copper wires itself, probably due to an magnetic insulation boundary condition. How can I get rid of that?
2. So far I was using identity pairs. Is this right?
3. What do I have to do to make the solid mech. simulation run? All I want is that the the wire can only push but not pull. Is there a methode to accomplishe that without using assemblies?
I added a short example file...
Florian
Florian
1 Reply Last Post 2013年1月16日 GMT-5 09:45
