2013年1月22日 GMT+8 16:19
you can only apply surface to ambient for external boundaries, but you can turn on the "surface to surface radiation" option in the main NITF node (at least in my 4.3a it's so) and then you can apply surface to surface radiation at will
2013年1月22日 GMT+8 16:23
Thanks Ivar,
I don't have the heat transfer module but do have the CFD module. This means that I can perform conjugate heat transfer but I can't use any of the radiation functions that come in the heat transfer module.
Cheers,
Josh
Thanks Ivar,
Cheers,
Josh
2013年1月22日 GMT+8 16:26
well as I have both that explains why I can turn them on, you have the choice, add another module or write out all the equations
2013年1月22日 GMT+8 16:29
I would like to write out the equations (they are simple for surface to ambient) but even so, you can't add it to the boundary because you can't add any sort of heat flux boundary between domains (or surfaces in 2D).
Can you think of any other way to get around this?
Thanks Ivar
Thanks Ivar
2013年1月22日 GMT+8 16:55
But you can add a "boundary heat source" on an internal boundary, indeed the "Heat Flux" BC applies only to external surfaces again
Nagi Elabbasi
Facebook Reality Labs
2013年1月22日 GMT+8 21:38
Through the Boundary Heat Source that Ivar mentioned you can emulate most of the other boundary conditions that are only applicable to external surfaces.
2013年1月23日 GMT+8 04:28
That is great! Thank you Ivar. You are such an asset to COMSOL. They should pay you (if they don't already)
2013年1月23日 GMT+8 04:29
Thank you Nagi. That is very helpful.
2013年1月23日 GMT+8 05:39
Hello again Ivar,
I am trying to write my own equation for surface to ambient radiation and am comparing it to another model in which I can define the default COMSOL version of surface to ambient. I am not getting the same results as the COMSOL version. I have defined my equation as -mat1.def.epsilon_rad*5.67e-8*(T^4-T_amb^4). Do you have any suggestions as to why this isn't working?
Cheers,
Josh
Hello again Ivar,
Cheers,
Josh
2013年1月23日 GMT+8 06:04
Hello again,
My apologies for the request. It was because I had defined one of the adjacent material properties wrongly. This meant that it affected the built in function but not mine. The problem is now fixed. Thank you!
Hello again,
