Adam Wahlsten
COMSOL Employee
2 years ago
2024年8月28日 GMT+9 17:48
Hi Aida,
If possible, it is usually better to enforce the limit on the phase field from the governing equations instead of setting a limit in the solver, since the latter will disregard the equations where your bound is violated. This means that you can get an arbitrarily large residual.
In version 6.2, with the Phase Field in Solids interface, you can use the Bounds subnode to a Phase Field Model node to specify these kind of inequality constraints.
If you are working with a phase field damage model like AT1, which is unbounded, an alternative approach to adding inequality constraints is to analytically derive the minimum energy that is necessary for a zero solution and add this as an additional source term in the phase field equation.
Adam Wahlsten
COMSOL
Hi Aida,
Adam Wahlsten
COMSOL
2 years ago
2024年8月30日 GMT+9 23:38
Thank you for your response, Mr Adam
However, I've noticed that the "Weak Contribution" sub-node doesn't exist under the " Phase Field in Solids" node.
How can I resolve this issue?
Magnus Ringh
COMSOL Employee
2 years ago
2024年9月2日 GMT+9 16:42
Hi Aida,
Could it be that you have not yet activated the Equation-Based Contributions checkbox in the Show More Options window (which you open from the top of the Model Builder window). Then you should be able to add Weak Contribution subnodes.
Magnus
Hi Aida,
Could it be that you have not yet activated the **Equation-Based Contributions** checkbox in the **Show More Options** window (which you open from the top of the **Model Builder** window). Then you should be able to add **Weak Contribution** subnodes.
Magnus
2 years ago
2024年9月4日 GMT+9 18:29
Hi Magnus,
Thank you for the suggestion! I tried to add the Weak Contribution subnodes as needed, and it worked perfectly.
Thanks again for your help!
Aida
Hi Magnus,
Aida
