Are there any known issues with COMSOL 4.4 running in virtual machines?
Posted 2014年2月6日 GMT+8 01:06 Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD) Version 4.4 2 Replies
                                                    While trying to solve a simple heat transfer problem with COMSOL 4.4 in a virtual machine I noticed 9 minutes were needed to find a solution. While trying to solve the same problem (exactly the same file), in the host physical machine, it took only 9 seconds. The problem in question does not require more than 2 GB of RAM to solve.
The physical machine is equipped with 64GB of RAM, and 2 CPUs (intel XEON E5-2630 V2 @2.6GHz), with a total of 12 physical cores (24 virtual processors with multithreading). The Virtual machine was running in the above physical machine, with allocated 16GB of RAM and 20 virtual processors.
During the calculation in the Virtual Machine, the CPU usage of the 20 virtual processors was always 99-100%, whereas in the physical machine they peaked at 50%. The OS of these machines are as follows:
- Host operating system (physical machine): windows server 2012 R2
- Guest operating system (virtual machine): windows server 2008 R2
This problem did not occurred with previous versions of COMSOL. Did this problem happened to you previously? How did you solve it?
Thank you very much.
2 Replies Last Post 2014年11月9日 GMT+8 19:45
