inverse heat conduction
Hi everybody, is it possible to solve an "inverse heat conduction" problem using Comsol solver? The aim is to find the boundary heat flux on a disk surface, using boundary and internal temperature values.
2 Replies Last Post 2010年6月28日 GMT-4 09:27
Posted: 1 decade ago 2010年6月24日 GMT-4 09:03
inverse problems, defined as mean square optimisation problems are readily solved, you need to define your global variable for the k heat conduction such that your overall conditions are fulfilled. This is what COMSOL uses internally for many specific BC definitions. Check the doc, more in the optimisation but you do not need the optimisation module for one variable. I.e. V3.5 structural doc how to apply torque moment loads
Have fun Comsoling
Hi inverse problems, defined as mean square optimisation problems are readily solved, you need to define your global variable for the k heat conduction such that your overall conditions are fulfilled. This is what COMSOL uses internally for many specific BC definitions. Check the doc, more in the optimisation but you do not need the optimisation module for one variable. I.e. V3.5 structural doc how to apply torque moment loads Have fun Comsoling Ivar
Posted: 1 decade ago 2010年6月28日 GMT-4 09:27
Many thanks!
Luigi
Many thanks! Luigi
