Jim Freels
mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
10 years ago
2015年5月6日 GMT-4 17:09
Have you used the compressible flow option within the CFD module. You will need that unless you model with your own equations using the PDE solver.
10 years ago
2015年5月6日 GMT-4 19:05
Yes i am using turbulent K-epsilon model which says compressible (M<0.3). i don't know how corrects the results will be.
but prior to that i want to learn how to define the BC conditions.
if you can guide me to any tutorial or procedure . Bcz i think i am not doing that correct.
Jim Freels
10 years ago
2015年5月7日 GMT-4 11:28
Sounds like you are not using the compressible flow physics. The M<0.3 is actually an incompressible algorithm, but adapted for minor compressible flows. For your application, you are well above M=.3 (as you said yourself, M=1 in the throat). This set of physics will not work. You will need fully compressible flow which is supported in the CFD module. there is actually a good example in the COMSOL model library. Look up
CFD module->high mach number flow->sajben diffuser. Spatlart-Allmaras and k-e turbulence models are supported.
Sounds like you are not using the compressible flow physics. The Mhigh mach number flow->sajben diffuser. Spatlart-Allmaras and k-e turbulence models are supported.
10 years ago
2015年5月7日 GMT-4 14:02
sajben diffusor is a good model to benchmark , thanks for referring.
Although the Mach number in throat section doesn't go to M=1 , hence no super sonic effect.
I would try to change the design and parameters and c if i get good results and will revert back.
Thanks.
Thanks.
10 years ago
2015年5月11日 GMT-4 14:10
Hi sajben diffusor is a subsonic model . whenever i try to apply super sonic boundary condition at the exit .
model shows an error of missing variable .
can you guide me to a model having supersonic BC's ??
Jim Freels
10 years ago
2015年5月11日 GMT-4 14:17
This would be a good question to ask COMSOL tech support.
Are you using the CFD module, and are you running compressible flow option ?
10 years ago
2015年5月11日 GMT-4 14:24
yes it is a compressible flow .
I am using the same module as sajben diffuser. "High Mach flow - turbulent flow:- spalarts allmara "
