[URGENT]Problem with boundaries-Solid Mechanics?
I've been wracking my brains with this for the last few days. I keep getting a convergence error which most likely is due to an error on the boundary conditions? Attached is my file with what I have. I would be forever grateful if someone could take a quick look and tell me what I might be doing wrong with my boundary conditions.
1 Reply Last Post 2015年5月11日 GMT+8 03:52
Posted: 1 decade ago 2015年5月11日 GMT+8 03:52
for me the main issue is that you have selected Geometry "assembly" mode, this means that all your domains are independent.
To check such a model, I would have started by applying a body load => gravity and use a time dependent solver just to check that the body remains "up" as expected, you will be surprised by the result if you try this in assembly mode :)
Then you two "contact pairs" are of no use because you need continuity to hold the shoulders in place. or at least a pair BC constraint must be manually defined.
The best would be to start with 2-3 bodies and you test out the Geometry "assembly" and "union" mode to be sure you understand these: have the 3 bodies intersect (i.e. cubes somewhat overlapping each other). Then fix one boundary and apply a gravity body load and do a stationary study (turn on the plot while solving for each solver steps to monitor better what is happening ...)
Hi for me the main issue is that you have selected Geometry "assembly" mode, this means that all your domains are independent. To check such a model, I would have started by applying a body load => gravity and use a time dependent solver just to check that the body remains "up" as expected, you will be surprised by the result if you try this in assembly mode :) Then you two "contact pairs" are of no use because you need continuity to hold the shoulders in place. or at least a pair BC constraint must be manually defined. The best would be to start with 2-3 bodies and you test out the Geometry "assembly" and "union" mode to be sure you understand these: have the 3 bodies intersect (i.e. cubes somewhat overlapping each other). Then fix one boundary and apply a gravity body load and do a stationary study (turn on the plot while solving for each solver steps to monitor better what is happening ...) -- Good luck Ivar
