2012年6月14日 GMT-4 13:58
at 886 MHz the wavelength in air is some c_const/886[MHz] or some 0.34 m, so if your volume is about a meter across or more you are at the begining of the RF domain (wavelength small compared to the model size). If the domains are slightly or well below the meter length you are in the "grey zone" in betwen good validity of RF and of ACDC (long wavelength compared to model and feature sizes). Stil l would choose RF.
Then for the field calculations, take a look a the RF model in the model library and on the main web site, you will find most responses discussed therein
2012年6月19日 GMT-4 11:35
Hi Ivar,
First, thanks for your help. My model represents a Silo of 20m height, and 10m diameter.
As you said, I am using the RF module because the wavelength is smallest than the cylinder dimensions (868MHz).
I have fixed the different subdomain properties of both blocks (together they form one), simulating air and wheat. The walls of the blocks are theorically connected to ground.
My idea was create a source of electrical field (a signal) in a point inside the block. And simulate the propagation losses of this electrical field across both different materials, and then view the plot graphics.
I'm using Comsol 3.4. I have searched in forums and discussions and I have not found anything like my model. Also I have searched in the model Exchange section and I didn't found a solution.
It's feasible the way I am proposing? If is not possible, what is the way to see these propagation losses across both materials?
Please, could you show me a similar model or give me a way to find a solution?.
Thank you so much
Francis
Hi Ivar,
Thank you so much
Francis
2012年6月19日 GMT-4 16:15
Sorry but 3.4 is really "old" for me, anyhow I did neither not do much in RF at that time, and nothing really in that direction either.
From what you explain, I believe that is feasible, if you have the material properties and the geometry it's should not be different from any other RF or optics propagation. Unfortunately I really do not remeber even how it was to set up a source point in 3.4, and I do not have 3.5 running etiher.
But there must be more v3 users out there, that was a stable version at that time, and eveyone out here cannot always run after the last version ;)
