Loop antenna
Hi I want to simulate a simple loop antenna which is made of copper. In this case I modelled a torus (360 deg), but I don't have any idea how to excite it. When I try adding port only errors occur. I will be grateful for any help.
4 Replies Last Post 2018年2月2日 GMT+8 20:35
Posted: 8 years ago 2018年1月28日 GMT+8 12:54
Cut a thin piece out of the loop and put a lumped element port there, with the direction of the imposed current (or voltage) from one side of the cut to the other. The "height" is the length of your cut segment, the "width" is 2* pi*r, where r is the small radius (i.e., of the wire, not of the overall loop).
Posted: 8 years ago 2018年1月29日 GMT+8 02:07
Could you please show me how to do that? I am trying but the effect is disappointing.
Posted: 8 years ago 2018年1月30日 GMT+8 13:04
I encourage you to post your file to this forum. Then, I or others can look at it and one of us may tell you what is wrong.
Posted: 7 years ago 2018年2月2日 GMT+8 20:35
I have the similar issue. I've modelled a loop antenna and when I excite it with lumped port, I receive different S11 result in comparison to CST. Both works at the same frequency but in COMSOL I see mismatch in my design. in CST: @ 2.4 GHz ---> S11=-30 dB In COMSOL: @ 2.4 GHz ---> S11=-15 dB
Can anyone help me?
Hi I have the similar issue. I've modelled a loop antenna and when I excite it with lumped port, I receive different S11 result in comparison to CST. Both works at the same frequency but in COMSOL I see mismatch in my design. in CST: @ 2.4 GHz ---> S11=-30 dB In COMSOL: @ 2.4 GHz ---> S11=-15 dB Can anyone help me? Thanks
