CONTACT PROBLEM
Hi everyone,
does someone know how to model a contact mechanical problem between two surfaces in which one of them is considered completely rigid?
I know how to model the contact, but i´m interested on the last thing (consider one of them rigid)!
thanks
Giulio
4 Replies Last Post 2011年4月21日 GMT+8 22:03
Posted: 1 decade ago 2011年4月21日 GMT+8 05:52
Did you try just a high stiffness for the rigid side?
Posted: 1 decade ago 2011年4月21日 GMT+8 21:19
a crazy idea: Have you tried to use a RBC (rigid body connector) on the "rigid side" this should "block" the part but I'm not sure how the contact solver will behave with a rigid object like that
Hi a crazy idea: Have you tried to use a RBC (rigid body connector) on the "rigid side" this should "block" the part but I'm not sure how the contact solver will behave with a rigid object like that -- Good luck Ivar
I had the same idea yesterday, it works!
Posted: 1 decade ago 2011年4月21日 GMT+8 22:03
Thanks, its always good to know
Hi Thanks, its always good to know -- Good luck Ivar
